bluebanana 0 Posted April 28, 2017 120 xxx km 109 xxx km on s15 dash ENGINE: - SR20DET 210kw 14.5 psi - Tomei PonCams - Garret GT-2860RS turbo - Earls braided turbo lines (oil line not fitted) - Walbro hi-flow fuel pump - Z32 AFM - Nismo 740CC Injectors - Greddy FMIC - Greddy intake pipe - Stainless steel manifold - Gktech dump+front pipe - Nismo catback - HKS super dragger muffler - ProfecB Spec2 EBC - Nistune Piggyback ECU - GFB deceptor pro - Morroso oversized sump - HKS Oil filter relocation - Powercoated rocker cover + modified breather (no T piece) - Gktech airbox - Gktech catch can - Gktech eccentric throttle wheel - Gktech rocker arm stopper - Battery in boot with isolator COOLING - 52mm radiator - Gktech fan - Low temp thermostat - Earls power steering cooler with braided lines - HKS oil cooler - Greddy swirl pot - Yoshi factory water pump pulley SUSPENSION: - Whiteline rear adjustable swaybar - Gktech front adjustable swaybar - Cusco fully adjustable toe/camber/traction/control rods - Hardrace rear knuckle bushes - 5 stud rear hubs - Gktech 5 stud conversion spacers in front - Gktech solid steering shaft spacer BRAKES: - Slotted rotors all round - Gktech abs delete - Gktech braided brake lines - Z32 front calipers - S15 brake master cylinder - Pmu B-spec pads rear - QFM front pads - Gktech master cylinder stopper - S14 wheels - Gktech wheel nuts DRIVETRAIN: - Toda lightweight flywheel - Exedy 3 puk clutch - Nismo slave cylinder - Nismo 1 way 4.3 diff - New front bearings, seals and gaskets in gearbox - Gktech shifter springs + bushings + pivot ball - Gktech braided clutch line - Cusco engine mounts - Nismo gearbox mount - Gktech solid diff bushes - Short shifter BRACING: - Cusco 3 point rear strut brace - Custom made 4pt boot brace - Custom c pillar brace - Ultra racing fender brace - Nismo power brace - Tomei 3 point strut brace - Spot welded complete interior + removed sound deadening - Cusco side intrusion brace INTERIOR: - Mongoose alarm system with 3-point immobiliser - S15 dash conversion (fully functional) - S15 floor mats - S15 scuff plates - S15 rear view mirror - S15 sunvisors - S15 dome light - S15 passenger seat - Nismo leather gearknob - Pivot headlight controller - Apexi ecv - Black headlining - Bride Gias Low Max replica driver seat - Genuine Bride rail - Nismo clutch pedal bracket - Fire extinguisher - Kill switch - Replica Defi gauges in air vent (oil pressure gauge doesnt want to work atm) - Autometer Boost gauge mounted on a piller BODY: - 2up carbon roof spoiler - Raybrig headlights - Kmak fbreglass front + rear lip - Gktech aero mirrors - RPS13 carbon fibre OEM centre garnish - OEM nissan rain deflectors - Shaved rear wiper + 3rd brake light - New oem door seals - ONE 80X plates included with sale No A/C. No ABS - not supplied No interior in boot, will be supplied. Can also supply (for the right price) : - S15 rear subframe with Gktech solid offset bushes installed, S15 rear lca's and Gktech weld in braces (not welded yet) aswell as a 2 bolt diff hat cleaned up and ready to go. - S15 driver seat - Ultra racing 4 point front lower brace Has 3 folders full of reciepts starting from first Australian owner.. Bad points - Boot paint is starting to crack (had too many spoilers in its life) and a bit of a dent left rear quarter quarter No joy rides, no stupid offers Share this post Link to post Share on other sites
S15 sxytime 30 Posted April 28, 2017 Location, price, receipts for work done / parts? Share this post Link to post Share on other sites
bluebanana 0 Posted April 28, 2017 Sorry. Price: $15 000 Location: Carlignford Have over 15k in receipts from first australian owner. Majority of work done myself as I'm a mechanic. Share this post Link to post Share on other sites
